Manually reset the check engine light
Old Oct 19, 2007 | 01:02 PM
ripull's Avatar
Default Manually reset the check engine light
Basically I left the ignition Key on and one of the Doors left open overnight, this obviously drained the battery to the point where I needed to jumpstart the engine. Once the engine was started and the battery was charged I had to reset the Clock and program the AM/FM channels. This was the only thing done and yet the Check Engine light came on and has not turned itself off. Because the battery was completely drained I am sure this was what triggered the engine light but unfortunately I am not sure if the Customer can reset this?
My question is do we have any way to resent this manually without taking to the dealer?
Thanks in advance
Old Oct 19, 2007 | 01:32 PM
hixx's Avatar
Default RE: Manually reset the check engine light
Disconnecting the battery and stepping on the brake pedal a few seconds should reset it. It probably set an O2 heater code due to low voltage on startup.
Old Oct 19, 2007 | 01:54 PM
ripull's Avatar
I will test this
Thanks
~ripull~
honeybadger11
Jul 19, 2011 10:35 PM
scotthochgesang
Apr 11, 2011 11:00 PM
ichimazda6
Jan 31, 2009 09:27 PM
bayarea96lx
Apr 16, 2008 02:33 AM
wirelesscop
Oct 17, 2006 03:15 PM
