Losing oil in Cx-7 2.3 - first time poster
Old Jan 17, 2020 | 10:31 AM
Stan DaMan's Avatar
Default Losing oil in Cx-7 2.3 - first time poster
Hi all first time poster. I am stumped so wondering if any of you have run into this issue. 2010 Mazda cx-7 2.3 touring with the turbo 116k miles. Engine going through about a quart of oil 700-1000 miles. There are no leaks anywhere, all gaskets good and oil plug etc. I recently put in a new turbo since my mechanic said that is probably the cause, well 700 bucks later same issue. I just purchased a new pcv and will put that in soon to see if that is the issue. Compression tests show all eual pressure on all cylinders 140 psi. No oil on spark plugs and they are of tan color. I also do not get any blue smoke at start up or acceleration. I also checked the intake tube and there is no oil in it. Where is this oil going? Any ideas of what I should check or do next? Can it be the oil catch rings around the cylinder? Any chemicals I can use to unclogged? I am original owner and changed oil every 5 to 7500 k miles using Pennzoil ultra plat synthetic. This burning oil issue started around the 100k mile mark. No other car issues what so ever. No codes, no stuttering or poor acceleration etc.
Thank you a bunch!
Old Jan 18, 2020 | 02:15 AM
That compression result is quite low, standard is 180 psi. Absolute minimum is 130 psi.
tnt4him
Feb 1, 2019 06:12 AM
mazda369
Feb 25, 2013 02:21 PM
burnsmat
Aug 19, 2009 06:54 AM
mx3_212
Apr 2, 2006 12:54 AM
the_gray_mazda6
Nov 14, 2005 01:46 PM
