Engine Assembly using Moly Graphite
I am assembling a 2008 CX 7 2.3 engine turbo and came across some information about using Moly Graphite on the main, rod and head bolts to get a more accurate torque. After some internet searching I found some say yes to grease them up while others say that the grease will cause movement with expansion and contraction from the heat. Does anyone have a knowledgeable opinion on this? To Lube on not to Lube, that is the question.
erbieb02
Jul 28, 2005 04:03 PM
