Cx7 wont start click noise
Old Jul 20, 2017 | 12:38 AM
Edson8's Avatar
Default Cx7 wont start click noise
Hello new to the forum i have a 2007 cx7 Mazda suv i drove it from Texas to Arkansas when i got to Ar it was making a noise by the belts and it smelled like when the car gets hot several days later it wouldnt start made a whrring noise couple times like the belts were locking up the it only mkakes a clicking noise when i try to start replaced baterry new! Took starter out had it checked at autopartssaid it was good and loosen the belts turned the pulleys checked all the fuses inside and under hood...still only a click around starter...can anyone help me with their exprience? Ty in advance
Old Jul 29, 2017 | 04:26 PM
WILLIAMCOLLINS1995's Avatar
Does it click all the time? Or only when your trying to start it? I know the high-pressure fuel pumps in these things can be awfully loud... I would try getting a stethoscope and narrow down where the noise is coming from.
Old Jul 30, 2017 | 09:42 PM
Edson8's Avatar
Default Thank you for taking the time
It clicks once tryng sounds like around starter area but doesnt try turning just a click and a buzz is heard like. (electrical buzz) i checked the belts and pulley see if they turn by turning with a wrench, im not sure if the ac one turns i dont see it turning,if ac compressor would be bad,would these be a cause for it not to even try to start?
Old Jul 31, 2017 | 05:40 AM
Easy thing is to remove the drive belt & try to start the vehicle.
Also try jump starting it directly off the starter motor.
Old Aug 3, 2017 | 02:45 PM
Edson8's Avatar
Default Starter jump
well i jumpstarted the starter and it engaged first time seemed and thought i was gonna start, fron there just hear the starter turn like is good ..when i put starter cable just whirling sound of starter but no turn on engine.i did remove starter to have it cheked and put it back on..any suggestions? Thank you
Old Aug 4, 2017 | 04:58 AM
You will need to also jump the starter solenoid to engage the starter motor to the flywheel.
This will only prove the starter is good & works, it won't start the car up, only turn the engine over.
(Re-reading your reply, I'm thinking the starter solenoid might be playing up. )
mdharrington
Mar 11, 2016 11:30 PM
dough_ja
Mar 3, 2010 03:55 PM
reese
Oct 6, 2007 09:01 AM
Tvaldez
Sep 6, 2007 07:56 PM
babyhuey
Apr 16, 2007 10:39 PM
