2007 CX-7 Stereo problems
Sorry stevegs59 I don’t have any suggestions but I have the same problem. Did you fix the stereo and if you did do you mind sharing?
thanks
Replaced stereo 3 times before finding one that worked properly. Original was a 6 disc changer. the one I found that worked is only a single disc, so I will continue searching for a 6 disc changer. Also discovered the units are built by Bose if that tells you anything about their quality.
