2007 CX-7 Stereo problems
Our 07 CX-7 stereo is screwing up. the lights will flicker on & off and it will randomly jump stations. Very irritating! Any suggestions to fix this?
Did you have any luck with your stereo?
Originally Posted by stevegs59
(Post 173182)
Sorry stevegs59 I don’t have any suggestions but I have the same problem. Did you fix the stereo and if you did do you mind sharing? thanks |
07 Mazda cx7 stereo problems
Replaced stereo 3 times before finding one that worked properly. Original was a 6 disc changer. the one I found that worked is only a single disc, so I will continue searching for a 6 disc changer. Also discovered the units are built by Bose if that tells you anything about their quality.
2007 cx-7 stereo problems
My has same problem 07 CX-7 stereo is screwing up. the lights will flicker on & off and it will randomly jump stations. Very irritating! Any suggestions to fix this?
