Valvoline multi vehicle transmission fluid FZ6, 8,9 red container
Old Apr 23, 2025 | 11:18 PM
Sett's Avatar
Default Valvoline multi vehicle transmission fluid FZ6, 8,9 red container
I just hit 60,000 miles and want to drain and fill the trans... Has anyone used this fluid... Says its for fz use... Otherwise im gettin aisin
Old Apr 24, 2025 | 10:45 AM
Any oil recommendation the best answers would be by you posting the basic vehcle information model, year and engine. Using the proper ATF is not guessing and guessing wrong can cause transmission problems.
Old Apr 24, 2025 | 03:35 PM
Sett's Avatar
Default Transmission fluid valvoline foe cx5 2018, 2.5l
Anyone use valvoline multi vehicle fz in the red jug
Old Apr 24, 2025 | 04:55 PM
Originally Posted by Sett
Anyone use Valvoline multi vehicle fz in the red jug
Yes we do occasionally in the shop for some customers along with other Valvoline products....?
However for customer I like as well myself owning a Mazda I prefer and use CASTROL ATF products. And I have had done several oil analysis to support my claims as to it quality and other attributes.
But FYI unless you ignored my first response then let me point out just because someone used it does not mean it was correct nor can many post the results using it unless they did an oil analysis before and then after choosing it.
Incorrectly using the proper OEM or minimum OEM requirements met ATF may not show those effects unlit months or several hundred miles of driving and then it generally costly to correct the wrong choice of ATF.
If in question always contact the oil suppling company direct in an example for this thread, Contact Our Customer Care Team - Valvoline Instant Oil Change
JPhardboiled
Apr 24, 2022 11:12 PM
boostmg
May 30, 2019 11:30 PM
doc4bax
Jun 29, 2018 12:14 PM
mzd507et
May 17, 2011 09:50 PM
mazda guy
May 13, 2008 01:02 PM
