Trans/Diff change Interval
Old Feb 18, 2026 | 11:52 AM
  #21
Originally Posted by bronze
What does the WD40 stand for? Water Displacement...not sure about the 40.
Water Displacement 40th formula.
Old Feb 18, 2026 | 12:59 PM
  #22
bronze's Avatar
Do these CX-5s use a 75W-90 gear oil for the trans case and rear diff?
Old Feb 18, 2026 | 01:02 PM
  #23
Now that I learned that I am not sure I would have named it WD40. I mean it took 40 times to get it right (for the time period)_and why would want your preceptive users to know that? LOL
I am sure many of us just remember our grandfather or dad telling us to oil our bicycle chain with WD40 LOL
Old Feb 19, 2026 | 04:03 AM
  #24
GL5 75w85.
I personally always used Genuine Mazda Oil
Old Feb 19, 2026 | 07:11 AM
  #25
bronze's Avatar
GL5 75w85.
Thanks, Grim. I'm a bit confused due to my ignorance about gear oil. I always thought gear oil was gear oil but now I'm seeing this word "Hypoid" attached to the Mazda spec. I assume it's important???
Old Feb 19, 2026 | 07:18 AM
  #26
You need to check your specific vehicle owner's manual.
Most models and years use the following.
Manual transaxle oil: API Service GL-4 SAE 75W-80
Automatic transaxle fluid: Mazda Original Oil ATF-FZ
Transfer case oil Mazda: Long Life Hypoid Gear Oil SG1
Rear differential oil: Mazda Long Life Hypoid Gear Oil SG1
Old Feb 19, 2026 | 07:34 AM
  #27
bronze's Avatar
Thanks, Lobstah. My owner's manual makes me work to get information from it. The index is essentially worthless. Anyway, I just found it and your info is exactly the same as in my owner's manual. There are no viscosity numbers. I have no problem using reputable alternatives if I know of any. But in this case, I'm simply not sure of reputable alternatives and it has me falling into your camp of just getting the Mazda products. Guessing they charge an arm and a leg but that still beats the hell out of replacing a drivetrain.
Here's one of those gear oil "alternatives" I found. I don't know if this is an acceptable alternative or not. Unless someone knows something I don't I'll stick with the Mazda products.
Amazon Amazon
Old Feb 19, 2026 | 07:39 AM
  #28
It's $33.50 on Amazon
Amazon.com: Mazda Gear Oil - 0000-77-SG1-QT : Automotive Amazon.com: Mazda Gear Oil - 0000-77-SG1-QT : Automotive
But most Mazda dealers sell it for about $25 a quart.
Old Feb 19, 2026 | 08:26 AM
  #29
bronze's Avatar
Thanks, L. I may go to the dealer. I need to establish one anyway. I bought my '24 CX-5 from a Lexus dealer. I have really only two choices where I live and even those two are a little bit of a drive.
I see both the trans case and rear diff take .48 qts each. But then you add up spillage and whatever else and I'll need two quarts to get the job done. As for the tranny fluid, I'm just doing a drain and fill (+ filter change), no flush so I'm guessing about 3 quarts??? Capacity according to my manual is 7.5 qts and in my experience drain and fills usually replace less than half the fluid. Thinking a gallon should cover it. Has this been your experience?
Old Feb 19, 2026 | 09:47 AM
  #30
I no longer DIY I use my local tech or the dealer but that should be about right.
I'm retired and too old now, I can barely bend over to tie my shoes...so I got Skechers
Long life of manual labor back and body abuse followed by 13 years of laboratory and computer desk duty employment.
With a few bad results from downhill skiing, motorcycle crashes and one hang gliding incident thrown in.
