Trans/Diff change Interval
Old Feb 16, 2026 | 08:30 PM
bronze's Avatar
Default Trans/Diff change Interval
2024 Mazda CX-5 Premium, 2.5L, 6 speed trans, 30,000 miles, 2nd owner
I'm curious when CX-5 owners change Transmission fluid/filter, Transfer Case, and Rear Differential fluid.
Old Feb 16, 2026 | 10:55 PM
Best at exactly your miles
If you want to help support a long trouble free life of those areas .
Old Feb 17, 2026 | 08:36 AM
bronze's Avatar
Next question. Is this one of those things where it is advisable to use Mazda brand fluids only or can an alternative quality brand name be used?
Old Feb 17, 2026 | 08:45 AM
I use Castrol first then other brands like AMSOIL Redline, Mobil 1, Pennzoil .....to name a few
Mazda does not formulate their own fluids.
Old Feb 17, 2026 | 09:28 AM
bronze's Avatar
I didn't think they did formulate their own fluids but perhaps partnered with someone who did and then made it proprietary. There's one of these cars (I think Toyota) where everyone says use the Toyota brand...I believe tranny fluid, not sure.
Old Feb 17, 2026 | 10:03 AM
They did not pardoner they contracted and that company is actually a global company you can find for yourself. And the formal as far as I am aware is not preoperatory. That's why there are other brands that state meets or exceeds Mazda fluids. (somewhere on this forum I already posted this information years ago)
Its the same for Toyota. Now there is a company that claims to be the best in the industry and maybe they are good quality but at the cost retail or even what they quoted me wholesale distributor cost they can keep it. LOL Not for as often as I service my fluids on any of my vehicles. LOL
I drained the Mazda fluid out of my engine and transmission at or before both were broken in. Somehow, I still like to see clear RED ATF instead of the dark green that Mazda has their ATF colored.
Most don't know that the RED color is ATF fluid is a dye and that history why is funny, sad but interesting!
Now if you want to get into more reasons.... the engineered and developed by me automatic transmission parts I sold stipulated to use Castrol, Redline or AMSOIL ATF only for the warranty.
Old Feb 17, 2026 | 10:31 AM
bronze's Avatar
Being new to Mazda and my CX-5 specifically, I still haven't found their recommended maintenance schedule. Haven't run into yet in the owner's manual or on the info system in the car. I'm guessing it's there somewhere I just haven't got there yet. Even so, I don't always agree with these schedules the carmakers put out. And I especially don't agree with anything they say is "Lifetime".
Old Feb 17, 2026 | 04:33 PM
Alexmed2002's Avatar
I wouldn't go further than like 50k miles to get all of those fluids changed. Always do a drain and refill only, not a flush.
Old Feb 17, 2026 | 05:02 PM
Aleeeex..... dude .... No that's correct!!!
reading things on the internet that are bad information again? lol .
Do you even know why there are two main reasons why not to do a complete transmission flush?
I will let you go research it before I respond. BTW I have answered that a few times on this forum?
And I have supplied dozens of pictures on this forum what the pan inside bottom, pan magnets and lower transmission looks like at various stages of service below 40k miles.
As for waiting until 50k miles... even that is not the best advice. Your transmission fluid is already contaminated with the break in particles after the first few hundred miles. There are also many assembly chemicals used that are dissolved as you acquire miles on the brand-new transmission while they don't cause any issues they can discolor the fluid and make for identifying actual problem area harder.
based on my experience with new automatic transmission the pan fluid and filter should be changed at least at or sooner than 300o miles from new. A full fluid replacement at 50k miles and for sure at 100K miles paying special attention to cleaning as much normal varnish build up on the valve body and solenoids.
To repeat when in doubt have a sample of your ATF analysis and see for yourself or role the dice and do nothing.
Old Feb 17, 2026 | 05:37 PM
I don't ever do flushes because it can cause issues, especially if the fluids were never changed often/at all. I'd personally get all my fluids done every 30k miles, but they do tend to last more miles. I know it takes multiple drain + fills for the old transmission fluid to completely empty out, but it's better than running the original fluid for "the life of the car" as Mazda says lol.
