Throttle Body cleaning
I have a 2016 CX-5 with 65k miles and want to clean the throttle body for the first time. Can I reuse the gasket or should it be replaced? Is it paper or a rubber o-ring type?
Make sure that you use 2 types of cleaners. On the electrical connection use only Electrical Parts Cleaner or better would be Mass Air Flow Sensor cleaner. On the actual metal parts of the throttle body use only Throttle Body and Air-Intake Cleaner. Yes they are expensive but then so is your Throttle body.
If you use anything else, then what I am recommending you stand a good chance damaging your throttle body.
