CX-5 **Seat Heater Control module?!**
Old Nov 7, 2025 | 01:27 AM
JMET's Avatar
Default CX-5 **Seat Heater Control module?!**
Hi, I have a 2014 CX-5 with heated seats and automated air conditioning. My drivers seat heats at max level with no lowering it, the heating elements seem Ok. Where is the seat heater control module located? Any help is much appreciated.The car is a European model with 2.2 liter diesel.
Old Nov 8, 2025 | 07:24 AM
cadcamjim's Avatar
The pdf I've attached is from "CX-5 Technical Guide Workshop Manual" and is from © 2012 Ford Motor Company of Southern Africa.
It states that "The seat warmer control unit is located on the bottom of the passenger-side front seat." That may change between LHD and RHD models.
Hope this helps.
File Type: pdf
Old Nov 9, 2025 | 01:24 AM
JMET's Avatar
Thank you very much, did not realize it is on the passenger side, have to go check it out. The (drivers side (I checked) has the big seat control module in it. If it is on the passenger side, how does it control both seat heaters? Usually each seat has its own control module. It is strange that the passenger side works fine but drivers side does not. Left hand drive car
Old Nov 9, 2025 | 09:27 AM
JMET... welcome to the forum
Old Nov 9, 2025 | 11:49 AM
cadcamjim's Avatar
The diagram shows that both seats are controlled by the same seat warmer control unit so the thermistor in the drivers seat must be wired into that thru a harness. The faulty component could be a thermistor, the control unit, or maybe a wiring issue. I would first try to locate the connectors going to the thermistors on both seats, unplug, check and compare the resistance of both thermistors with an ohmmeter. They should be about the same measured with the seats "cold". If they are not, then the thermistor on the drivers seat is likely faulty.
If you need more details on the wiring (color codes, connector styles, etc.) let me know and I'll dig deeper into my document collection and see what I can find.
Old Nov 10, 2025 | 11:08 AM
Broken cables/wires/plugins are common on older model years.
It might be as simple as unplugging and using some contact cleaner.
I believe some models/trims may require buying the entire seat bottom as some units are molded into the seat itself.
Good luck either way and welcome to the forum.
Old Nov 15, 2025 | 03:17 AM
JMET's Avatar
Thanks for the comments. I will start checking the system and I have an upholstery guy also who can help with this.
53Canuck
May 17, 2026 10:29 AM
Bocatrip
Feb 28, 2025 02:47 PM
bigbro
Mar 23, 2023 06:31 PM
rainbow
Dec 31, 2008 03:57 PM
xlc210
Nov 30, 2007 02:15 PM
