Thermometer Monitor Engine Coolant Temperature -40F
Old May 1, 2024 | 05:45 PM
Originally Posted by 2014CX5GTAWD25
I have not. This is a topdon Phoenix elite. It's a $900 scan tool but it could be wrong. It's the only one I have. I've got a cheap Bluetooth code reader and an innova code reader with a physical cable but I don't think either of those will read these PIDs.
I have followed this thread and wondered why you were getting those readings? Maybe just use another device to at least compare to confirm?
Old May 1, 2024 | 05:52 PM
2014CX5GTAWD25's Avatar
That is a great idea and I'd have done it if I had another one to try. I don't really know anyone else that has an actual scan tool I can use.
Old Jan 21, 2025 | 05:59 PM
theskitzofrantic's Avatar
Default Anything??
Has anyone ever solved this problem??
Old Jan 21, 2025 | 06:44 PM
Nope. Car runs great. I have chalked it up to something screwy with the scan tool I'm using. The sensors are new and they test perfectly with a multimeter according to the factory service manual so the fault must lie with the scantool and I still don't have and won't be buying another one anytime soon.
Old Mar 8, 2025 | 11:24 AM
amateur_wrench's Avatar
@2014CX5GTAWD25 Did you ever figure this out? Sounds like your car ran normally. I've got the same reading, but my car is stalling out after a few minutes of driving and it throws an error saying there's an inconsistent temp reading between sensors. I suspect that's the root cause, but wondering if this -40 thing around the thermostat is a red herring versus a real symptom.
BTW, your question about fuel pulse width, that's an error in the software. The range is specified in seconds, but it's showing a reading in milliseconds. So it's always out of range. Just ignore it.
Old Mar 8, 2025 | 11:33 AM
Car still runs well. I think it's just the scantool. If I had access to another one, I'd verify it but I don't.
Are both your sensors reading the same or close to the same?
Old Mar 8, 2025 | 11:38 AM
Great question. Answer is no. After a couple of mins of idling, getting ~1V from the one on the engine block (#1), and ~3.5V from the one near the firewall(#2). #1 voltage keeps dropping as engine temp increases (as expected), #2 barely moves. I suspect #2 is bad. About to replace that and will see what happens.
Were your voltages consistent between the two?
The reason I asked about the thermostat is that if it's not allowing coolant to circulate properly to the heater core (and the #2 sensor along the way), it may be more than just a sensor.
***editing to add that I removed the #2 sensor and did the hot water test and saw it return some pretty normal-looking readings. Which is why I suspect I have a circulation issue.
Old Mar 8, 2025 | 12:24 PM
Both sensors are new and read the same temps.
Maybe use a heat gun to check before and after thermostat readings or check the temps at the sensor locations.
junbugx
Mar 9, 2023 02:52 PM
turbobrd
Oct 8, 2022 08:58 AM
lakotie
Apr 29, 2008 06:42 PM
edsmith01
Jul 25, 2007 03:10 AM
