Replacing side door mirror CX5
Old Nov 29, 2021 | 06:36 PM
Kchaudha's Avatar
Default Replacing side door mirror CX5
2017 CX-5 Touring. My daughter swiped a mailbox and smashed the passenger side mirror, I presume this is not complicated to replace, I have done it before on other makes of car.
My query is about heated side mirrors. It didn’t come with heated side mirrors but is the wiring already set up for it? Should I just replace with a heated mirror?
as an aside, mine does have blind spot monitoring already
thanks!
Old Dec 12, 2021 | 01:16 PM
Kchaudha's Avatar
Bumping up. I went with the "exact" aftermarket replacement. No heat.
However the BSM off light is not turning off. Does anyone know how to reset this? I tried the battery disconnect for 15min and also tried turning BSM on/off in the settings on the screen.
Thank you!
Old Dec 13, 2021 | 05:22 AM
Is the BSM warning light flashing in each mirror glass when first starting the vehicle?
Old Dec 13, 2021 | 06:22 AM
Kchaudha's Avatar
No it does not
Old Dec 14, 2021 | 04:57 AM
Then you have a problem. Did you plug the wiring loom into the mirror glass before fitting it?
Babine
Jun 20, 2024 03:26 PM
whiskeysquirrel
Aug 11, 2021 01:50 PM
ricpd
Apr 29, 2021 08:59 AM
Gds07
Mar 16, 2021 06:54 AM
tomej
Jan 25, 2018 04:14 AM
