Replacing fuel injector
Old Jan 12, 2025 | 06:58 AM
wille100's Avatar
Default Replacing fuel injector
Hello, i have a code on cylinder 3 fuel injector. I am going to replace it on my own, do i need to relearn the new injector or is it just plug and play?
mazda cx5 2.2 skyactiv-d 2014
thanks!
Old Jan 12, 2025 | 08:15 AM
Below is my opinion, others may have different ones.
I do not replace fuel injectors myself as it can be easy to damage them and other parts when replacing.
Also verify the replacement injectors are the same as the OEM.
Some older injectors have been replaced by newer versions would require you to replace all of them for proper performance.
You will also need to replace the stopper ring, O-ring, back-up ring, and Teflon seal of the fuel injector with new ones.
Do not remove the fuel pressure sensor from the fuel distributor
Old Jan 15, 2025 | 06:13 AM
The replacement fuel injector requires coding/registering with the PCM/ECU.
Old Jan 15, 2025 | 08:16 AM
Thanks, I forgot that as well.
That is why it is best to have a trained technician do it.
lovettgb
Feb 7, 2023 11:14 AM
Lai1800
Jan 17, 2022 09:27 AM
sticky12
May 16, 2012 11:59 AM
derek31806
Aug 8, 2008 09:48 PM
jeff1202
Jun 27, 2005 08:01 AM
