Recommended Tire Pressure - 38PSI
Old Jan 18, 2022 | 07:39 PM
  #51
sherp's Avatar
... you should always adjust the proper tire pressure shown in the auto manufactures tag in the door jam, the best time early morning before any traveling is done with no direct sun on any of the tires. ...
What do you suggest to get a reliable reading, as our nearest station is somewhere 2km away, and I don't have an air compressor. Or would that distance be immaterial? TY
Old Jan 19, 2022 | 03:36 AM
  #52
GAsierra's Avatar
For basic inflation at home (or while traveling), something like this works reasonably well: Slime tire inflator (#40052). Can run from the car's 12V or cigarette lighter plug. You can set the desired pressure, and the machine will automatically stop once the pressure is reached.
For a good, reliable reading of tire pressure, consider a gauge by G.H. Meiser: Accu-Gage H60X.
If setting at a fueling station's gauge, you could set the pressure to several PSI above your desired setting, head home, then the next morning use a decent gauge to set it exactly yourself (before you start to drive the car that day).
Old Jan 19, 2022 | 06:38 AM
  #53
sherp's Avatar
Thanks. Will search something similar in our area (not in the US). Isn't the gauge in the Slime accurate enough?
Old Jan 21, 2022 | 09:52 AM
  #54
GAsierra; posted a couple of good choices, however whatever gauge you get you need to confirm that they are accurate and if not do the math adjusting for their inaccuracy.
Shadfactor
Nov 8, 2019 05:47 PM
ZDragonMan
Dec 3, 2007 06:22 PM
cariengon
Oct 25, 2007 10:20 AM
UrbanmanUSA
Jun 14, 2007 02:08 PM
trungvo409
Aug 15, 2006 02:56 PM
