Rear brake pads keeps breaking
Morning
Mazda CX5 2016 here
Rear brake pads keeps breaking (1/4 of pad breaks off ) I replaced it 3 months ago and it is already broken.
I hear a metal noise when slightly breaking...
sounds to me that the caliper piston might be slamming into the brake pad and eventually breaks part of it ...weird ..
The caliper was replaced yess performing service mode yet it still breaks the brake pad ....
Anyone have any ideas?
thank you
Phil
Mazda CX5 2016 here
thank you
Phil
A caliper unless it was damaged and you would see it visually cant do what you are describing.
Because they are brakes and you cant solve the problem I recommend you take it to a service shop in your area. Not sure where Vista is as there is serval cities named that but if in USA . If Vista CA then Firestone would be an easy choice. If none close then shop for a service shop that is ASE registered. There are several in your area if CA.
Waiting to find and correct the problem could in the worst scenario cause the rear wheel to lock up at any time or vehicle speed and cause the car to rear steer severely.
it actually does a noise on both sides but only rear left breaks the pad.
both calipers R new using service mode.....
Now that you added that you have concerns describing BOTH rear brake and their components
Based on your limited information the service, a step or installation procedure was overlooked or not done correctly. Guessing at this point could get you into more problems than resolving. Your rear brakes will need to be removed.
ASE
Yes Ill probably go to see another mechanic but would like to find out more before doing so
Thank you for the advice
Some members are not auto mechanics or brake service qualified and your description really should be looked at by a service shop that is experienced in brake service.
ASE
ASE
Ok
thnks
You are driving a 2016 vehcle with equal technology. It is not like vehicles manufactured pertaining to the running gear ,suspension and chassis from about 2002 and older. It DOES require updated training to service them.
Any service shop that randomly replaces parts is not a qualified as they think and are "guessing" at the cause of the problem simply hoping that replacing parts will solve the problem..
If you find a shop that has ASE signage on their building and displays their employee's certification you will find one that is authorized to display the sign in which to do so they must employee at least one ASE certified mechanic (current ) or better and ASE Master technician.
I respect that you have DIY for 45 years then you should know that by your own posting a service procedure was done incorrectly or possible a part(s) was installed incorrectly.
Btw your 45 years experience I have been ASE Master Technician for 34 years and current
So you can take my advise or members that align with your thoughts..?
ASE
ASE
ASE
ASE
Ill see a ASE mechanic
Thank you
