Question on power problem
Old Sep 11, 2023 | 09:42 AM
tony m's Avatar
Default Question on power problem
Hi all i'm new on here and new to the CX5 2.2 sky active. my daughter recently bought this used model for which iam the designated first call for problem solving LOL
After 2 months it developed a problem where at about 70 mph it loses power to accelerate . No warning lights on dash limiter off , I'm thinking a MAF sensor or something . any help or ideas would very helpful . Thanks in advance
Old Sep 11, 2023 | 10:26 AM
After 2 months it developed a problem where at about 70 mph it loses power to accelerate. No warning lights on dash limiter off , I'm thinking a MAF sensor or something. any help or ideas would very helpful. Thanks in advance
Welcome to the forum.
Well needless to say without any ECU DTC's it is going to be a difficult to diagnosis limited information.
Basically, if you are experiencing any power drop off the ECU would have a DTC or at least a pending DTC and the monitors may also be in fault. So, you need to connect to the ODBII diagnostic connector with a scan tool (NO BLUE TOOTH DEVICE) and retrieve the information.
All guess or suggestion on a single or multiple part that support the engines operation and especially as described by you would be confirmed with the proper ECU scanning and should be done before changing any part.
Old Sep 11, 2023 | 10:39 AM
tony m's Avatar
Thanks for your quick reply Callisto ....Scanning sounds like the next step
Old Sep 11, 2023 | 10:49 AM
When you acuate more throttle % the ECU compensates and adjust the other components, if the % does not match the ECU for changing values you will get a DTC!
Braty
May 22, 2024 08:17 AM
Mazdacx-5x1
Jun 4, 2021 11:50 PM
Paul Smifff
Sep 19, 2019 03:23 PM
dellarose
Aug 29, 2012 04:12 PM
dellarose
Jun 26, 2012 07:13 AM
