Question about connecting dashcam
Old Jul 25, 2021 | 05:25 AM
jplank1983's Avatar
Default Question about connecting dashcam
My wife and I recently bought a 2020 Mazda CX-5. We have a dashcam that we want to connect. In our old vehicle, we connected the dash camera to the cigarette lighter. I've been watching videos on youtube about connecting directly to the fuse box via something called a BlackVue Power Magic Pro. I don't know a lot about this (or about cars in general) but can anyone tell me if this is a safe and reliable method to connect a dash cam? I'm worried about using something that's a bit sketchy and possibly damaging my vehicle.
Old Aug 3, 2021 | 09:43 PM
chowman90!'s Avatar
I have one in my 2019 Signature and also in my 2015 Mustang. Works fine. It enables you to set your voltage cuts offs so that the camera doesn't drain your battery. Pretty easy to install as well.
Old Feb 10, 2022 | 07:40 PM
arnoldinho's Avatar
hey jplank - there's another way to power up your dashcam. You can actually tap into the power going to your mazda's rearview mirror. I recently installed a dashcam on my CX5 as well, but used an adapter instead. It was quite an easy solution all said n done.
I posted a vid on Youtube. Check it out, you might be interested.
Old Feb 10, 2022 | 07:42 PM
arnoldinho's Avatar
Can someone show me how to NOT include the gigantic previews LOL I'm just trying to share the link without my face being plastered on here.
Old Feb 24, 2022 | 03:18 PM
calvinl's Avatar
https://youtu.be/zZoM3FzUjEc
That video does not have park mode for the cam, does it?
Old Feb 24, 2022 | 03:40 PM
Whenever possiblele it is always better to tap into a existing wire at the fuse box with a high amp rating then you add on device. Then run the power lead to the new added device. This way you protect your MAZDA, your device and if there is a power outage supply it will in almost every case be the fuse you added and not the main fuse you tapped into. Running a small cable is not difficult nor is it time consuming unless 5 minutes is time consuming? LOL
If you do want or persist in running a jump lead only with no separate fuse or relay protection off an existing wire, then you really should find out its load rating.
Before you use BlackVue Power Magic Pro you may find that most Dashcams do not drain a battery if set up correctly. And most dash cams do not run continuallsy in video recording mode. It is very rare that you would need an additional device like the BlackVue Power Magic Pro for most installations of a dash cam.
Old Feb 24, 2022 | 03:51 PM
calvinl's Avatar
hi Callisto, can you help my issue with dash cam, https://www.mazdaforum.com/forum/maz...zda-2-a-49155/
thanks.
g3lo
Jul 4, 2022 04:51 PM
ecwsCX5
Jun 15, 2021 10:10 AM
Bluefell
Apr 5, 2021 12:39 PM
jcweir49
Aug 3, 2020 11:15 AM
Jim_Nazium
Sep 20, 2015 01:45 PM
