P258B Vacuum pump circuit/range performance
Old Aug 11, 2020 | 11:14 AM
dannysconnect's Avatar
Default P258B Vacuum pump circuit/range performance
Hi all
Wondered if there is someone who can help me here
2014 I have a Mazda CX-5 2.2 Diesel
I am getting a fault code P258B
Vacuum pump Circuit/range performance
The vacuum pump is mechanical(attached to the end of the camshaft) - can someone tell me which sensor is responsible for setting this code?
I didn't think there was a sensor that reads the vacuum pumps pressure apart from the brake booster sensor. Could this be the sensor that is responsible for reading the vacuum pumps pressure and sending fault information to the PCM?
Interestingly I carried out a vacuum pressure test on the vacuum pump
The pressure is pretty accurate if not slightly higher (27inHg) my gauge may be slightly out
HOWEVER - Live data on ForScan shows that the brake booster pressure sensor is reading about 7inHg.........
this is as much info as I Know
Can anyone help?
thanks
Danny
Old Aug 12, 2020 | 03:00 AM
Very common issue for the pump to die a slow death and eventually fail.
I've replaced probably 50 of them.
There is a recall on some CX5's worldwide for vacuum pumps.
1st contact Mazda to check.
If it's not involved, book it in with Mazda for a vacuum pump test, its carried out using their factory diagnostics tool.
Old Sep 4, 2021 | 12:29 PM
okenfolDZ's Avatar
Default question
Hello Danny!
Did you found out what caused the problem? I have the same issue.
Old Sep 5, 2021 | 01:38 PM
Hi
im sorry I did not reply to this sooner or put the outcome on here after finding the fault
yes it was the vacuum pump which was faulty
Old Oct 25, 2021 | 03:21 AM
Loveridge141's Avatar
Originally Posted by dannysconnect
Hi
I’ve had the same code come up on my Mazda 3 2014 Sport Nav 2.2L.
How much does it approximately cost to fix this issue?
Thanks
Val Gonzalez Jr
Nov 25, 2016 08:59 PM
mike 02
Oct 27, 2008 01:49 PM
99millenia
Sep 26, 2008 06:57 PM
rcampora
Apr 28, 2008 11:16 AM
frist44
Aug 26, 2005 05:02 PM
