New 2021 CX 5 GT - Couple of questions
Old Jan 7, 2022 | 08:34 AM
jkeck's Avatar
Default New 2021 CX 5 GT - Couple of questions
Hi all. Just got a 2021 CX5 GT and have a couple of questions (sanity check) please. When using the remote start from the phone app, is there a way to set the temp in the car? Doesn't seem like it.
The other question is around the auto high beam feature (when enabled). I can't find a way to turn on (or off) high beam (manually) if/when the auto high beam feature is enabled? I'd be surprised this is how it was designed? For example, high beam during heavy snow is bad but I could see the system turning it on if no other cars are around.
A few days in and we are very impressed with the car.
Old Jan 7, 2022 | 09:37 AM
GAsierra's Avatar
2021 CX-5 Owner's Manuals @ MazdaUSA.com
According to the Connected Vehicle Owners Manual v1 (p.43):
Remote Engine Start (Except manual transmission vehicle)
Start the engine using the Remote Control.
Press and hold[START]. When the engine starts, the temperature of the climate control is
kept at the same temperature as when the engine was last turned off.
Old Jan 7, 2022 | 10:10 AM
Chris!'s Avatar
Without running out to check, I think you just put the light staik on the low beam position. I can't respond to remote start issue, I've never used it.
Old Jan 7, 2022 | 02:07 PM
chickdr19's Avatar
Originally Posted by Chris!
Without running out to check, I think you just put the light stalk on the low beam position. I can't respond to remote start issue, I've never used it.
This. The auto feature is enabled when the stalk is pushed forward and off when pulled back.
Old Jan 8, 2022 | 07:36 AM
jkeck's Avatar
Thanks much.
GregP74
Jul 16, 2021 02:01 PM
fisherking
Jun 3, 2021 10:56 AM
p4ulamiller@gmail.com
Oct 7, 2015 10:41 AM
Epoxy
Jan 5, 2010 10:05 AM
