Mazda CX5 won't start, turns over then dies
Old Jun 15, 2015 | 02:09 AM
Rinn396's Avatar
Default Mazda CX5 won't start, turns over then dies
With no signs at all I got in my mazda after stopping at shops, push the starter, it turn over but lost rpm immediately and stopped. Several attempts same thing. Turned over but died immediately. After getting it towed home, I tried the next morning, same thing for several attempts then drained battery. Got auto elec out, 4 hours later after all error codes were cleared, the air intake sensor code can up? Disconnected the sensor and the car started straight away! Plugged it back in, car stopped straight away. I called mazda who said that no sensors had been sold as of yet? I drove car without sensor connected, it jolted on low speed to stop but ok while cruising. I bought air flow intake sensor reconnected and problem solved. Running perfectly once more. The mechanic thought it was fuel pump problem initially because of behaviour of the car turning over. Hope that helps any future Mazda owners or auto elects experiencing same symptoms.
Old Jun 15, 2015 | 06:31 AM
I've had a CX5 with very similar problem. Cause was a local mechanic serviced it, didn't refit the air filter box lid properly. Dirt & debre got sucked in without being filtered, something got stuck in/on the AFM messing up its output signals.
Old Jul 8, 2017 | 11:09 AM
cippydip's Avatar
Smile Thank you!! This solved my problem.
I had the same problem with my 2014 CX-5. The engine turned over, then died. After watching some YouTube videos on how to replace the sensor, I followed your suggestion, disconnected the MAF sensor and the car started right up. Got the new sensor at the dealer because no other auto parts stores had it in stock. Believe it or not, it was cheaper at the Mazda dealer than special ordering it at 4 major parts stores. The replacement took 2 minutes, at most.
Thank you for posting this solution. It saved me a bunch of time and money!
Old May 16, 2018 | 01:42 AM
jose.r's Avatar
Default very helpful post
Followed steps here and appears i have same issue. Part is on its way from Mr Car Parts. Will see how the part goes.
Old Feb 20, 2020 | 08:02 PM
Stephanie Malone's Avatar
Default my 2014 doing the same thing
my 2014 cx5 is doing the exact same thing. I just change the fuel pump thinking that was the problem and it wasn’t. I am going home now to check this sensor!
Old Feb 21, 2020 | 08:43 PM
Since my previous post, I've had 3 CX-5s in the last 3 yrs or so come thru the shop with failed MAF sensors.
Old Feb 22, 2020 | 02:37 AM
we are pretty sure that’s what it is we disconnected tje MAF sensor and the car started right up definitely ran rough but it started and it ran I just ordered a new one and it should be here tomorrow so hopefully that’s the fix
Old Jul 21, 2021 | 09:36 AM
vibhoosama's Avatar
Smile
Thank you for your info it helped me identify the MAF fault and saved time and money.
Old Jun 23, 2022 | 04:51 PM
Micholgirl's Avatar
Same issue here, the dealer wants $236 for the part, is that too much? I will check auto zone etc.
krazyk011
May 30, 2011 08:23 AM
ViperSkeele
Aug 15, 2008 10:52 AM
rabidmongoose
Aug 13, 2008 03:16 AM
Nomen
May 6, 2008 11:15 PM
K3l3v
10
Jan 27, 2008 09:28 PM
