Maintenance Schedule / Oil Change
Old Feb 7, 2018 | 07:15 PM
mazda_nc_dude's Avatar
Originally Posted by Puyapim
The oil change interval should be dependent on your driving routine. If you are short tripping a lot then I might think about 5000 miles oci. If you do mostly highway then 7500 miles will be okay or you can use the oil life monitor and go by that
I agree. I will do the first one at 5000 miles for sure and then either every 5000 or 7500 miles.
Old Feb 8, 2018 | 07:56 PM
nickndfl's Avatar
Every 6k-8k miles for me. I did notice that my 2016 uses a bit of oil between changes.
Old Feb 8, 2018 | 08:32 PM
Not good news. Wondering how the 2017-2018 are holding up. I used to have a 2008 VW Passat that I had to fill up with oil in between changes and it was not fun.
Old Feb 8, 2018 | 08:41 PM
nickndfl's Avatar
It's like 0.5 quarts between changes, but I think some of that is from traveling > 80 mph and new engine design with loose rings and valves.
Old Feb 8, 2018 | 08:46 PM
shipo's Avatar
How is that not good news; using a little oil is good for the engine. Said another way, the engine *should* use a little oil.
Old Feb 9, 2018 | 03:24 PM
nickndfl's Avatar
My Honda CRV did not use a drop in 150k miles, but the CX-5 is slightly more refined overall.
Old Feb 9, 2018 | 06:57 PM
shipo's Avatar
You may believe that, but more than likely some oil was consumed and the volume was replaced by fuel or condensation. If you'd had your oil analyzed it would have told the story.
Old Apr 12, 2018 | 06:02 PM
CharlieXray's Avatar
My 2016 uses noticeably no oil between changes, however I do change the oil and filter religiously at 5,000 miles (give or take a couple hundred). I don't have any experience otherwise, but I've always used the Mazda 0W-20 Moly Oil since it was new as well.
Old Apr 13, 2018 | 10:04 AM
shipo's Avatar
Our 2016 uses maybe a quarter of a quart during a 10,000 mile oil change interval; I also use the Mazda Moly 0W-20 oil.
Old Apr 17, 2018 | 12:24 PM
Carfo's Avatar
mazda cx5 manual specifies there's two schedules based on road conditions and driving habits. one schedule has you changing oil every 5k miles, the other every 7.5k miles, with other things to check at various intervals. i would read the difference between the schedule 1 and 2, see which applies to you, and follow that schedule.
personally, i like the online manual as it beats the hell out of the PDF in terms of layout
https://s3.amazonaws.com/tsd.mazdaus..._OM/howto.html
