Help Needed: Error Codes
Old Jan 4, 2019 | 11:16 AM
CROCK's Avatar
U codes are purely communication faults, usually they are nothing to worry about.
Put a new maf sensor on it and took care of all the codes for some reason, communication codes are now gone along with other codes, must have a fail safe if maf goes bad. Strange
Old Jan 5, 2019 | 03:54 AM
Quite often faulty components can corrupt signals and appear as U codes.
Old Jan 26, 2020 | 10:51 AM
Laurentiu Sebastian's Avatar
Hello everybody! I own a 2015 Mazda 6 2.2 diesel. I got engine check light and errors with SCBS, DSC (dinamic stability control) and TCS (traction control) warning light . I ve tested the car, and for the check engine light I have P0101 code (mass air flow sensor), and for the rest U0433, U0401. Did you have this problem and how did you fix it? Do you believe that by changing de MAF the other symptoms ( SCBS, DSCM ,TCS) will disapeare??
Thank you and sorry for my english.
Old Jan 26, 2020 | 11:06 AM
drflanders's Avatar
​​​​​​Mine was the airflow sensor defective. It triggered the other codes.Changed air flow and problem solved.
simmonsp5
Sep 21, 2023 04:49 PM
velocita
Sep 1, 2012 02:33 AM
pxx8511
Oct 16, 2007 12:57 PM
poet1234567
Aug 16, 2006 11:52 PM
lightnix
Nov 7, 2005 10:27 PM
