Headlight Auto / off confusion
Old Apr 22, 2024 | 04:17 AM
Unpat's Avatar
Default Headlight Auto / off confusion
I have been driving my 2022 cx5 for 28 months now. I was recently pulled over at night for no headlights.
I have driven the car during night with the switch off . Even if it’s off the headlight used to come on as soon as the wheel started turning.
The only thing I noticed was the cluster gauge will not light up, but the streets In front of me were illuminated by the lights from my car . Is it just the dlr? Does the tail lights come on when the switch is set to off ?
If the headlight doesn’t come on when it’s off , are the DLR lights that bright ?
thank you .
Old Apr 22, 2024 | 05:40 AM
ADS-B's Avatar
You should, at the minimum, keep your lights stalk on the "Auto" position and if you're driving at night turn it to the "on" position. Tail lights on are a must.
Old Apr 22, 2024 | 09:57 AM
Unpat's Avatar
ok Einstein. Thanks
Old Apr 22, 2024 | 10:24 AM
Alexmed2002's Avatar
In the off position the daytime running lights come on, but your tailights and interior lights will still be off. If you leave your headlights on auto like @ADS-B mentioned, or turn them to the on setting then you have nothing to worry about and everything will work. My girlfriend did the same thing with her car at night when she first got it and you could only see the lower rear bumoer reflectors from behind in the pitch black.
Old Apr 22, 2024 | 04:47 PM
ADS-B's Avatar
You're welcome!
Old Apr 27, 2024 | 06:17 PM
orion's Avatar
I'm not quite getting this as I thought that you could NOT drive with the lights to 'OFF' as does not the switch rotate back to 'Auto' , in which case the headlights and rear lights should come on?
Old Apr 27, 2024 | 06:43 PM
I've not heard of that on the CX-5 personally. It's just the left turn stock that has the dial switch which you can manually turn the lights through its different settings.
Old Apr 27, 2024 | 07:45 PM
orion's Avatar
"It's just the left turn stock" Is that a typo for 'stalk' ? If so, yes , that's what we have in Canada, but the four way switch will not remain in the off position, it springs back to auto.
Old Apr 27, 2024 | 08:54 PM
ondersma80's Avatar
It's the same in my USA 2022 cx-5. If you turn to off, it stays off. Off does turn off the rear marker lights as previously mentioned. Off is off. On is on. Auto is where it does it for you as long as the ambient light sensor is working right.
Old Apr 28, 2024 | 11:04 AM
Yes that's a typo on my end. I meant the turn signal stalk. Is there any chance you could record it springing back and attach it to the thread?
