CX5 stalled at a light
Old Sep 21, 2017 | 04:26 PM
ladder13's Avatar
Default CX5 stalled at a light
Driving my CX5 today, the car stalled and I had a difficult time getting it started again, but finally did after 3-4 minutes.
After the stall I put it in park and pushed the start button. It sounded like the starter was stuck as the engine kept trying to turn over, even when I released the button.
The car did this multiple times while at the light, then finally started.
Maybe it wasn't getting fuel? There was a weird clicking sounds coming from the engine, do bad injectors sound like that?
Since that issue I've driven 20 miles with no problem, but leery it may shut down at any minute. I'm on vacation and tommow is Friday, should I take it to a dealer asap, it is under warranty.
Ideas?
Old Sep 21, 2017 | 04:49 PM
paris1's Avatar
Take it in and see if there are any fault codes stored on the ECU. That will tell where to go from there.
Old Oct 13, 2017 | 04:38 PM
ladder13's Avatar
I haven't taken it in yet, I've been traveling without the car. I just put a code reader on the car and saw no codes
Any other ideas?.
I'll probably take it in next week sometime.
Old Oct 14, 2017 | 02:35 AM
lincolnunit's Avatar
I don't know a whole lot about cars, but I once had this issue with a Chevy Impala 4 cylinder. Issue had something to do with battery not getting charged or something related. Car ran fine again after I let car run for a long duration. The issue was likely me leaving a light on inside which drained the battery.
Old Nov 9, 2017 | 08:25 PM
ladder13's Avatar
No codes thrown and have had zero,issues since. Still baffling to me.
Old May 5, 2023 | 03:37 PM
Markafn's Avatar
Did you get the issue sorted , my 2018 cx5 2.2d has now stalled at a roundabout three times ..same symptoms as yours ..no error codes 🤷🏻‍♂️🤷🏻‍♂️
Old May 5, 2023 | 04:02 PM
How old is your vehicle?
Those starter clicking sounds are the classic signs of a bad battery.
The Mazda OEM battery is not very good and doesn't last long, I only got one year out of mine.
Have the battery load tested to find out if that is your issue.
If it is, replace it with a better quality one, and if it's 3 or more years old you should probably replace it with a new one anyway.
Old May 5, 2023 | 10:06 PM
schmieg's Avatar
You're right about those batteries. The one in my 2014 died in January, 2016. I couldn't get it to hold a charge and called AAA. They played with it and finally came to the same conclusion I had about two hours earlier. The guy had the right battery in his truck and tried to sell it to me. I had the AAA membership that gives me a free battery once a year if it fails. The guy grumped, but put it in. It's still running fine on that free AAA battery and it sits outside in all weather.
footballer
Jan 17, 2013 07:53 PM
MrSpike118
Sep 22, 2010 03:07 PM
Captain Mazda
Feb 7, 2010 12:11 AM
mazdamx6mm
Aug 17, 2009 03:59 PM
Tallisen
May 3, 2008 06:51 PM
