2014 Cx-5, Crack but no start
Old May 2, 2023 | 10:18 AM
Nswaine's Avatar
Default 2014 Cx-5, Crack but no start
Hi
I have a 2014 CX5 that is cracking but refuses to start, work I have done so far trying to get it running is listed below
  • PCM Tested
  • Injectors tested (one replaced due to short in circuit)
  • Fuel pressure test
  • Oil Strainer Replaced
There is no faults in the car. If anyone could shine a bit of light on this it would be much appreciated. Thanks
Old May 2, 2023 | 10:40 AM
CarpeDiem's Avatar
When you say “cracking” do you mean the engine turns over (starter motor works) or it fires intermittently but doesn’t keep running? What does “PCM tested” actually mean? Assuming it’s a gasoline engine (who knows) is there a spark?
Old May 2, 2023 | 10:58 AM
Nswaine's Avatar
Yes engine turning over but no start. Sent the PCM away to get it tested to make sure there no problems inside such as a chip burnt out Etc. This is the 2.2 Skyactive D engine
Old May 6, 2023 | 10:28 AM
Where, and how are you testing the fuel pressure?
Has it been scanned for fault codes?
Old May 6, 2023 | 10:36 AM
Nswaine's Avatar
We tested the fuel pressure using the Mazda Dignostic computer. No fault codes are coming up on the system.
Ckbrown
Dec 17, 2022 09:04 AM
Esctiger23
Aug 6, 2022 06:17 AM
savvatomsk
Jul 24, 2021 03:45 PM
expatCanuck
Oct 19, 2019 07:04 PM
Din.adeel
Jul 24, 2016 12:40 PM
