CX5 non crank
Old Sep 28, 2023 | 02:33 PM
jaffa's Avatar
Default CX5 non crank
Hi guys, I have a petrol CX5 I stop
it will not crank, I have full battery (12.8 volts) the push start turns green, the gear indicator shows correctly on the dash board, I have checked all fuses and relays, if I put power directly to the starter relay with IGN on the vehicle will start and drive as normal, but will not start from start button any ideas or advise please
thanks
Tony
Old Sep 29, 2023 | 07:17 AM
Probably won't work but have you tried placing your FOB up against start button and tried starting?
If that works, the FOB battery needs replacing.
Always possible the start button itself is faulty.
Old Oct 1, 2023 | 04:13 AM
jaffa's Avatar
Thanks I have put new Batteries in both fobs but still no Crank, I have Noticed that all the dash ignition lights go out when I try to crank (even the clock display) but all returns when I release the Start Button
Old Oct 1, 2023 | 10:01 AM
CarpeDiem's Avatar
Cool
When was the last time the OP had his battery load tested? A simple voltage reading is useless. A declining battery can cause this issue, have the battery properly load tested.
Old Oct 1, 2023 | 10:59 AM
Good advise ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
This is always a recommend procedure to do first if after changing the remote battery does not have any effect.
Acemaddog77706
Oct 31, 2022 04:40 PM
gsimmons
Jun 10, 2022 11:05 AM
bobs51
May 24, 2015 10:56 AM
RichardLee4261
Feb 14, 2011 08:52 PM
