CX5 2015 Speaker connections
Old Jun 22, 2022 | 03:52 AM
Fredsworld's Avatar
Default CX5 2015 Speaker connections
Hi,
I'm happy with my CX 5 from 2015.
It's without a Bose installation.
The sound could be better and i will change the OEM speakers into a Compo set of Hertz.
When i remove the doorpanel, i find the connector for the midrange speaker.
But so far my knowledge reach will be the left side speaker and tweeter from the same point at the radio.
But where are the wires coupled together from the tweeter and midrange/woofer doorspeaker?
I have to place the filter there for the compo set.
Who can help me further?
Old Jun 22, 2022 | 05:44 AM
This is what I could find
File Type: pdf
File Type: pdf
Old Jun 22, 2022 | 06:14 AM
Those wiring diagrams are for the 2012-2014 pre-facelift CX-5. 2015 should have the MZD connect system. The MZD system uses a TAU ( Tuner and Amplifier Unit). The speaker wires come from the TAU and not the head unit.
Old Jun 22, 2022 | 06:15 AM
Fredsworld's Avatar
Thnx for the PDF's
It's a little bit hulpfull for searching the color of wires.
But where are the wires coming together(location) see the red circles?
Someone knows it?
Old Jun 22, 2022 | 06:18 AM
Fredsworld, do you have MZD connect with the master command switch / toggle between the handbrake & gear lever?
Old Jun 22, 2022 | 06:26 AM
Fredsworld's Avatar
Yesss, the buttons are there.
It's a 2015 CX-5 facelift model with electronic handbrake button.
Old Jun 22, 2022 | 06:32 AM
Those previous wiring diagrams are not for your vehicle.
I will see If I can get hold of the facelift model wiring diagram for you.
Old Jun 22, 2022 | 11:43 AM
Sorry, those are all I could find.
Grim will probably have better luck.
Old Jun 23, 2022 | 04:09 AM
I congratulate you in your effort.
I only found out the different setup/wiring in my 2016 facelift when I went to upgrade my sounds.
Old Jun 23, 2022 | 09:45 AM
TB250's Avatar
I haven't been able to find any up-to-date service manuals/wiring diagrams for the '20+ models. Everything on eBay says it covers the '21 and '22 MY vehicles but none contain any of the vehicle specific information. They are 2016 service manuals.
