CX-5 partial engine replacement
Old Mar 25, 2020 | 07:03 PM
Graeme's Avatar
Default CX-5 partial engine replacement
Question for the experts.
Had a head gasket failure on my 2015 CX-5 Grand Touring Diesel.
The dealers have told me that I did not blow the head gasket, but the receipt said that they did a partial engine replacement.
The part number for the partial engine is SHYE02300B.
Can anyone identify what SHYE02300B.entails?
Cheers
G
Old Mar 25, 2020 | 07:54 PM
My engine cross over guide ,which is not always accurate, shows that to be a long block only no accessories?
This is a supplier of low mileage engines and trans,missions we often use in he shop .
Old Mar 25, 2020 | 09:03 PM
Graeme's Avatar
Cheers Callisto.
I was suspecting it was a short motor. Long motor is a good indicator that the coolant leak added to the recall fix made for a very bad combination.
Gotta love warranty fixes.
Old Mar 27, 2020 | 04:22 AM
Different people have different interpretations of long block vs short block.
When Mazda replaced the engine, it would come in a crate, fully assembled ie block, head, sump, rocker cover & timing chain. ( no manifolds, pipes, hoses etc) .
Depending on other factors, they may of fitted a new turbo assembly, vacuum pump, and possibly intake manifold & injectors.
They will reuse the fuel pump, water pump, coolant hoses, & depending on condition intake manifold & egr system.
They will fit new fuel pipes , thermostat & gaskets/seals.,
Old Mar 27, 2020 | 08:51 AM
AFTERMARKET none vehicle manufacture or dealer
Long Block= Complete engine head and lower short block No other bolt on parts unless specifically noted
Short Block= Engine with no head. No other bolt on parts unless specifically noted
Old Mar 27, 2020 | 11:46 PM
Graeme's Avatar
Cheers guys.
What defines a long & short motor hasn't changed since the days I worked at Commonwealth Chrysler in Braddon.
The only major bolt-on component they replaced was the vacuum pump, but i'm surprised that they would re-use the water pump.
Old Mar 28, 2020 | 05:05 AM
We have replaced heaps of these engines, can't recall a water pump being replaced, nor any fault afterwards.
These engines are known to have a weak head gasket. Hence the reason Mazda is replacing the engines well out off warranty.
Old Apr 2, 2021 | 12:00 PM
Aaron Sinwell's Avatar
Pretty sure my head gasket is blown on my 2014 CX5 Grand Touring, but I'm the second owner and it's at 110k. Probably no chance of them going this far out of warranty, huh?
Old Sep 19, 2021 | 01:22 PM
Breno1981's Avatar
Just got mine done under warranty. 2nd owner 2015 grand touring cx5.
Old Sep 20, 2021 | 06:19 PM
CarpeDiem's Avatar
Cool
The poster hasn’t been back, but I doubt he realized this thread is for diesel engines only.
Kirsten Lamb
Sep 15, 2021 10:48 PM
JCT
Apr 2, 2020 02:48 PM
JCT
Mar 20, 2020 10:22 AM
Hans-NM
May 3, 2019 09:48 PM
