CX-5 Cylinder Deactivation
Aside from that, the only way to truly tell is to pop the hood and look under the engine cover, the cylinder de-activation components are all piled up along the rear (firewall side) of the motor on top of the valve cover. If there is pile of stuff, you got it. If you can clearly see the coil packs and valve cover, than it does *not* have cylinder de-activation.
side note, do not update the PCM past version D, it re-maps the ECU and completely neuters the car and is irreversible.
I am a dealership tech and normally a PCM update is only done when/if there is a problem. We don't just go around checking the versions of modules for ****s and giggles. Module updates only pay .5 hour and the risk/reward/time ratio is not worth it.
Also, what the newest version does isn't a bug, it's a feature. It makes it more fuel efficient, with slight modifications the shift points, fuel trims, a few things.
a coworker updated his 2.5 turbo Mazda6 and hates it now lol womp womp.
It most likely does and DO NOT buy a pre 2019 2.5 Turbo, regardless of model. The motors are flawed and leak coolant from behind the turbo and require a cylinder head replacement. if this repair has already been completed, you are good to go.
