Creaking /popping
Old Apr 21, 2025 | 07:45 PM
Ian96ser's Avatar
Default Creaking /popping
2018 cx-5 AWD 2.5
creaking, popping over small bumps and when performing low-speed turning maneuvers, (parking, making right or left turns at intersections) particularly when on the brakes and even worse when going downhill while braking and making left or right turns. Can be felt in the steering wheel and even if I put my hand on top of the shifter.
Does NOT make the sound when going uphill at any speed and not much sound replicated when in park as well.
I lubed the control arm bushings, outer tie rod ends, the ball joints, tops of the struts, sway bar linkage and bushings. Made no difference.
any advice? TIA
Old Apr 21, 2025 | 11:59 PM
Your Mazda needs to be inspected up on a drop hoist where the suspension drops free.
Because you either did want to or in a hurry ..fill more member info it’s harder to make guesses based on your operating environment which is important with concerns like yours.
Also you left out important service information about your Mazda.
Think of this way when asking help on a forum, as if your were talking to a service writer and they filled in your basic vehicle information.
Old Apr 22, 2025 | 06:24 AM
Ian96ser's Avatar
Default Creaking/popping from front suspension/steering
Done. Also, use a lot of bumpy roads etc. cause pa roads are terrible.
i do know what I’m doing somewhat, which is why i attacked the suspension first, because it really sounds like a binding bushing.
i had the car on stands and checked the bearings as well. No noticeable wiggle.
service history: reflashed trans computer (it was shifting really hard and still knocks a bit into first when coming to a stop), new evap canister and solenoid, FYI My daughter did hit a curb pretty hard a couple months ago when practicing parallel parking.
Old Apr 22, 2025 | 07:47 AM
I have the same issue in every vehicle I drive...it's my 72-year-old knees
Old Apr 22, 2025 | 08:51 AM
The downshift feels at times when coming to a slowdown is from you not completely stopping. It will not harm the transmission and is normal
I would be careful not to use any product that is petroleum or solvent based on bushings it will not only cause the bushing to become nosier quicker but also deteriorate them thus shortening their service life. n
Old Apr 22, 2025 | 09:32 AM
Ian96ser's Avatar
gotcha. Well too late for that. Now, at this point I am pondering if it is the cv joints or the ball joints. Maybe strut bearings up top?
Old Apr 22, 2025 | 09:44 AM
Try a DIY method of testing.... with your garden hose spray down everything and while it is wet see if the sound diminishes or goes away completely. This will help locate the noise because as the water dries the sound will return with a slightly different tone and may be easier to pinpoint.
InfiNorth
Apr 24, 2019 09:00 PM
Tammo
Feb 18, 2015 03:17 AM
TheDigitalMage
Jun 11, 2014 10:45 PM
hairyg
Apr 28, 2009 06:56 AM
