Coolant light
Old May 19, 2025 | 12:40 PM
BOBBYFUTS's Avatar
Default Coolant light
Every time I start my engine the coolant light comes on then goes off after I've driven it for 5 minutes,is that a normal thing,my level is fine and I get no temperature issues 🤔
Old May 19, 2025 | 01:04 PM
Scan the ECU and find out what DTC is in pending and also permeant file.
No its not normal.
Just because you do not have a check engine light does not mean the ECU is not working out a problem!
Old May 19, 2025 | 03:26 PM
hsdejong's Avatar
There are Mazda CX-5s without a temperature gauge, but with a warning light instead.
When the engine is cold, the light is blue. Once the engine reaches operating temperature, the light turns off.
If the light turns red, the engine is overheating.
Old May 19, 2025 | 04:11 PM
You are almost correct.... so don't quit your day job yet.
The ECU activates the blue dash light if and only if the temperatures fall below a set threshold generally on the next engine cycle engine start up. The blue light goes off at 129.9F which is simply an indicator that the water, transmission oil and engine oil have reached the first temperature point indicating that the cooling system and fluid temperature control during cold start is functioning as it should to help an informed driver that there is no engine and transmission and coolant problems. Naturally if there were you would likely also get the check engine light activated. But the blue light going off is not called optimal fluid temperatures. So you should not really state drive normally yet! If that were the case, then those living in ambientes most of the year all day from sunrise is in the high 90s to triple digits exceeding 110F+ would likely never see the blues light even at start up or it would go off in a minute or less from cold start. BTW the Mazda thermostat is for most regions of the world 195f so in a sense operating temperatures would be if using a digitally manual temperature gauge or device not connected to the ECU for fluid temperature information then collecting the temperature readings the transmission and engine oil normalize at the same temperature which would be just under the thermostat at approx.. 180F . So then what about the opposite for people living in extreme cold operating environments, the blue light would take much longer before going out and the operating fluids ,engine and transmission may never reach even 180F and in many documented service records often not even 160F or less.
Honestly the blue light is IMHO not worth confusing the average vehcle owner and Mazda should have just stayed with RED your engines dead LIGHT. Because most drivers will ignore the lights anyway... IMH!!! LOL
And now lets open the discussion to why all auto manufactures temperature gauge seem to have controlled everyone to accept that in the middle of the gauge is correct operating temperature. LOL Riddle me that batman! lol
Old May 20, 2025 | 02:14 AM
BOBBYFUTS's Avatar
Default Thanks
Thanks all for the advice,much appreciated
Steve Parker
Apr 22, 2021 09:13 AM
rtaylor
Mar 22, 2021 08:44 AM
rlb
Jun 24, 2014 02:16 PM
spacey
Aug 19, 2007 09:53 AM
mazda guy
Nov 12, 2005 03:33 AM
