Can I use 235/35/19 on my 2015 CX-5?
Old Apr 5, 2018 | 06:06 PM
EPortillo's Avatar
Default Can I use 235/35/19 on my 2015 CX-5?
I would like to ask if anyone has used 235/35/19 on a 2015 CX-5 GT. Do I need to make any modifications?
Old Apr 5, 2018 | 06:38 PM
shipo's Avatar
The thing is, nobody is likely to use 235/35 R19 tires on a CX-5. Why? They are way smaller in diameter than the OEM tires; if you have them mounted on your car your speedometer and odometer will indicate higher speed and more miles than actual.
Old Apr 6, 2018 | 08:18 AM
EPortillo's Avatar
Thank you @shipo. I purchased a set of used 19" Ruffino Boss rims and they came with the tires.tires have 35% thread on them, I thought I could use them while I look for a new set of tires, but was wondering if they would damage my car.
Old Apr 6, 2018 | 08:36 AM
shipo's Avatar
No, I doubt you'll damage your car, but your engine will be running higher RPMS at any give speed and your speedometer and odometer will be off by a pretty fair margin.
Old Apr 7, 2018 | 11:28 AM
mazda_nc_dude's Avatar
235/35/19 would be too small in diameter as shipo pointed out. I assume you could use 235/55/19 though, you could double check with a dealer.
Old Apr 7, 2018 | 08:10 PM
EPortillo's Avatar
Thank you for your input. I will contact the dealer and inquire. I have looked into new tires and I think I will go with the 235/50/19. They will work I think.
Old Apr 7, 2018 | 08:27 PM
shipo's Avatar
The correct size for 19" wheels is 225/55 R19; if you go with 235/50 R19 you're still going to have speedometer and odometer error in that they're read roughly 6% high (i.e. too fast/further than actual).
Retarding the wheels you bought; do they have the correct bolt spacing (5x114) and offset (45mm)? If not you may still have issues.
Old Apr 8, 2018 | 02:41 AM
If you run your new tyres, your speedo will be reading 70mph when your actual speed would be 60mph. Big difference. 12.83%.
https://www.1010tires.com/Tools/Tire...ismetric=False
Old Apr 8, 2018 | 08:20 PM
Be sure to check out 235/55/19, not 235/50/19. Also make sure that the 235/55/19 work with the OEM 19" wheels.
Old Oct 15, 2023 | 06:38 AM
RedCX20204me's Avatar
Ran 235/50/19 for 30k miles; even had 235/40/19 winter tires, lots of unsafe fun on those.
Those all were running on a paid off, expired warranty 17 non-turbo so I had fun with it
refin_hadi
May 24, 2022 10:57 AM
Gloveman
Feb 6, 2017 03:50 PM
Andujar
Sep 24, 2015 11:39 AM
