Airflow Query
Hello. I would just like to ask about the airflow of my CX5. I notice that everytime the weather outside reaches 25 degrees (or below) the air coming from the vent is very minimal or sometimes does not even work. Is this part of the feature and is there a way I could disable it?
Thank you.
Thank you.
Thank you for your reply. I set it as manual. I notice that everytime the outside temperature goes to 20 degrees the flow of the air goes very low even if i turn the fan to number 3 or 4. But when I turn off the A/C switch (fan only) the flow of the air becomes normal.
Thank you for your reply. I read about this in the manual but it says there that aircon may not work if the outside temperature is 0 degrees. In my case the outside temperature is only 20-25 degrees.
alhindyfan
Sep 10, 2024 08:03 AM
Karla Szaflarski
Apr 29, 2020 07:47 AM
