2021 Mazda c/m-5 87 octane
Old Dec 25, 2021 | 10:28 AM
  #21
reubenvabner's Avatar
Its a common sense assumption that this is done regarding the ECU/ECM/PCM on vehicles, so sort of but not always and not really so much with the MAZDA. Maybe read my previous response. Specifically, the Skyactiv ECU. I have been developing power parts for the 2.5 and have monitored what the ECU does. I did about a year ago run one complete tank of 87 octane Chevron and compared the results and data logging on which was close to the exact same miles and travel route. I can tell you everything was less, power and MPG. While I did Not DYNO the 87 because (WHY), (LOL) I have run several DYNO runs setting up and running the same DELTA each time from the base line completely stock MAZDA 2,5 to each addition I made on the engine or something that may affect the engine output?
Callisto: You are talking about 2.5NA engine? or 2.5T? Thank you, Reuben
Old Dec 25, 2021 | 10:36 AM
  #22
This is why I say that you can go to the bathroom, sit for a few minutes, and come out with a Neutron Bomb.
Old Dec 25, 2021 | 10:42 AM
  #23
In that last response you are asking about it is not Turbocharged MAZDA. In my other responses on this thread, it applies to MAZDA specific Turbocharged, and none turbocharged engines and other platforms 4cyld. 2002 and newer Turbocharged Supercharged engines.
Old Dec 25, 2021 | 10:53 AM
  #24
DITTO. Unless you have the Turbo, why would you want to use anything OTHER THAN 87 Octane gas? Do you have money that you regularly burn to start your grill in the evening? Please send the extra money to my personal charity if you have no use for it. Or send it in to help pay down the $29 Trillion U.S. debt outstanding.
"Cheaping Out"..... You kill me.
Best Regards, RMV
The first part of your response show and please don't take this as insulting, the lack of understanding about Turbocharged engines. So many think that a turbocharged engine is always boosting the engine.....if that were the case the MPG would be in the low teen all the time. In actuality the way the ECU and electrical and mechanical limiters and controller on a factory Turbocharged engine are set is for a linear boosting except under about 75%+ throttle angle and then the maximum set boost is allowed but only for a short period with a rapid decline to protect the engine.
Below is a slightly modified Turbocharged PT Cruiser with mechanical and ECU adjusted operating perimeter's. This PT does low 12's in the 1/4 mile and 0-60 in about 5 seconds. But even with some changes in the boost control you will notice the boost monitor going to full allowed and adjusted boos and then as the MPH and different high RPM reached starts to decline. Without the limits the engine would over boost and likely heat and blow the engine. It is the same with a MAZDA Turbocharged engine.
In the end its your vehicles and you can do whatever you want and use what-ever fuel in it you want.
ASE
bobm
May 31, 2021 06:09 PM
bobm
Dec 8, 2020 08:46 AM
pcardoza
Feb 8, 2019 06:14 AM
JCraig
Aug 25, 2007 05:19 PM
Alucard
Nov 3, 2005 11:47 PM
