2020 CX-5 "moaning" noise from center dash area.
Hey folks!
Wondering if anyone else has had this issue and if so what worked to fix it.
Issue: At seemingly random times there is a "moaning" noise that comes from the center section of the dash, lower down. The sound is similar to when you pull a straw through a plastic drink lid and it makes the "clown horn" noise. Like a shaft or rod passing through a rubber gasket or bellows of some sort.
I suspect it is an issue with the blender door in the HVAC ducts. It happens when sitting at idle, it happens while driving, it happens after the ignition is off, just random times. It has gotten worse with the Florida heat.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
I recommend to do a HVAC system cleaning
It is a simple DIY service that anyone can do.
Then after you do that see if the noise returns. If it does at least you will have a good smelling sanitized HVAC system!
One example of a good product
Amazon.com: Lubegard 96030 Kool-It Evaporator and Heater Foam Cleaner (2 Pack) : Industrial & Scientific
see this thread post # 452- 453
Mazda3 Things I like to do - Page 46 - Mazda Forum - Mazda Enthusiast Forums
I use this product, but it is a bit more cost then one I posted earlier.
: Self-Rinsing Foaming A/C Coil Cleaner for Cars | DWD2
jbliss1234
Sep 9, 2024 06:58 AM
