2017 CX-5, 63k miles, second time the high pressure fuel pump has been replaced
Old Jun 3, 2023 | 12:15 PM
  #21
m5xguy's Avatar
Originally Posted by Balaur
BTW, to tighten the fuel rail nut to the correct torque, I've used an open-ended wrench with a luggage scale and calculated the required force (well, weight) to pull the spanner with, according to its length. ..
Very creative! The 'standard' way would probably be to use a crow's foot extension on the torque wrench, with torque adjusted accordingly. But as you've shown, there's more than one way to get that job done.
I will try to understand what is wrong with the old pump and get back to you. The initial report is that the pump seems to be seized in the depressed position (well it could not be seized in the out position, right? as the camshaft lobe would have pushed it inside)
It looks challenging to disassemble it easily, even more so non-destructively. ....
No need to drive yourself crazy trying to get the pump apart gracefully. Just finding out that it was seized is quite a bit more than we knew previously. If you're able to do it, and find out something else, then that would be a plus. But no problem or disappointment whatsoever if that can't be done.
Great work, all the away around, in getting your vehicle back on the road. Every DIYer knows how good it feels to have complete success with a project, and we also enjoy reading reports like this one. Well done!!
Old Jun 5, 2023 | 07:08 AM
  #22
Nice to you were able to solve your issue.
Very informative post as well.
Dustin1
May 6, 2025 01:16 PM
DarrenR
Mar 16, 2024 06:43 AM
Beaker80
Nov 9, 2022 04:35 AM
steeve
Sep 12, 2022 04:34 PM
Ronny64
May 13, 2012 07:30 AM
