2015 cx5
Old Feb 4, 2023 | 02:48 PM
pacifichwy's Avatar
Default 2015 cx5
Rear hatch latch. Not opening . Replaced with new actuator. Still not working. No clicking noise.
. Thanks for any comments. Other doors work fine.
Old Feb 6, 2023 | 09:00 AM
First check your fuses (I have no idea which on the rear hatch actuator motor is hooked to).
If the fuse is good, you should get a click unless the actuator and/or wiring is bad.
Get the new actuator tested and make sure it is actually working and go from there.
Old Feb 6, 2023 | 10:09 AM
Welcome to the forum.
I think I may have tried the acuator before installing or have checked the suspected actuator when I removed to verified it was the actuator and not the control or power supply during actuation? That said you will need to re-step your service process and determine the true problem.
I do recomed for any issue to always varify that it is a the parts that has failed or causeing the problem before replacing it. Often times many will assume a part has failed replaced it and in doing that service inadvertanly caused other added problems.
Old Feb 14, 2023 | 05:02 PM
hillcountryhorn63697005's Avatar
Default Rear hatch lock
2015 cx-5...My rear hatch latch lock will not work sometimes during cold temperatures. When it warms up, it works.
Nestor
Jun 3, 2022 07:30 AM
refin_hadi
May 24, 2022 10:57 AM
Cokey
Jun 20, 2021 10:35 AM
Andujar
Sep 24, 2015 11:39 AM
