Mazda CX-3 Engineered with breakthrough SKYACTIV® TECHNOLOGY, the CX-3 subcompact crossover delivers unmatched driving dynamics right alongside outstanding fuel economy.
5th and 6th gear gas cutting and stalling
Old Aug 31, 2025 | 04:55 AM
Rea665's Avatar
Angry 5th and 6th gear gas cutting and stalling
I own a 2018 Mazda CX-3 1.5L diesel vehicle. My car has 85,000 km on it. When driving in 5th and 6th gears, it first cuts the gas and then stalls, lighting up 4-5 warning lights. When you pull over, stop, and start the vehicle, the lights go out and you can continue. However, it happens again after a certain period of time.
Has anyone else experienced this issue and found a solution?
Old Aug 31, 2025 | 09:39 AM
The first question that will be asked is to provide :
All current DTC
All permanent DTC
I/M Monitors status
When was the last service done and what was it.
Old Sep 1, 2025 | 10:09 AM
Rea665's Avatar
All current DTC
All permanent DTC
I/M Monitors status
Maintenance was performed 2000 km ago. All filters, engine oil, and brake pads were replaced.
The warning lights that came on during the malfunction were: lane departure warning light (LDWS), tire pressure warning light, i-stop light, collision warning light, smart city light, and TCS light.
The most recent incident occurred while driving on a long road, and the situation I described several times before repeated itself. Again, while driving at 160 km/h, this time the engine light came on. We drove like that for a day. (I added injector cleaning fluid at the gas station), and then the engine light turned off by itself.
Old Sep 1, 2025 | 10:41 AM
Your information should be reviewed by a service a shop that has a Trained Diagnostic Service Technician with OBDII diagnostic systems and other electronically monitored and controlled systems on your MADA. And from your response this should be done ASAP.
Do not use a shop that only has a basic mechanic. There would be to much guessed diagnosis at your expense.
For a better service shop 1.0 to max 1.5 max hours diagnostics would find and give recommendation to resolve the issues.
Old Sep 1, 2025 | 02:12 PM
Rea665's Avatar
Thank you so much. I will do ASAP.
retread888
Aug 30, 2025 03:52 PM
CarloC
Oct 23, 2023 03:56 AM
tormu
Jul 7, 2018 11:02 AM
93f250
Jan 22, 2017 07:13 AM
Milleniaowner
Jan 6, 2009 10:07 AM
