where's the fuel pump?
Old Feb 22, 2009 | 06:21 AM
bloodsweatgears's Avatar
Default where's the fuel pump?
i have a 92 b2200 5spd, f.i. replaced ecu with a rebuilt and coolant temp sensor. still wont start. sprayed a little ehther into the air intake and it started and only ran for a couple of seconds till ether burned off. could it be the fuel pump and where is it located? i don't hear the buzz sound pumps usually make when you turn the key. any help would be great. i also changed plugs wires cap and rotor
Last edited by bloodsweatgears; Feb 22, 2009 at 06:25 AM. Reason: forgot to mention
Old Feb 22, 2009 | 08:47 AM
hixx's Avatar
In the gas tank.
Old Feb 28, 2009 | 02:00 AM
Cusser's Avatar
For fuel injected and automatics: in the fuel tank. Tilt the truck bed for access, or emove tank, or remove truck bed (recommend tilting):
Disconnect cable release and the two rubber hoses at the gas fill assembly (loosen and raise bed slightly [see below] to remove the larger one).
Remove the three 17mm-head bolts on the passenger side bed frame.
Loosen the corresponding bolts on the driver's side, about about 2/3 of the way. Use a 16 inch 2 x 4 on a floor jack to lift up the passenger side of the bed Tighten the jack, and up tilts the bed. I used a 1/4 inch drive ratchet, with 1/4 inch socket and a #2 Phillips bit (and two hands to hold it straight). All mine loosened, but maybe because I'm in Arizona there was no rust; I replaced with 7mm head hex head screws (4mm thread x 8mm long, with a wavy washer). To line up the bed so I could get the three 17mm head bolts back in on the passenger side, the bed needed to be jacked up a little, then I could use my weight to shift the bed a little from one side to the other.
catrina
14
Jul 1, 2010 10:45 PM
Variety=Spice
Oct 11, 2007 11:14 PM
ferret
Dec 7, 2005 11:18 PM
ruidasilva
Mar 17, 2005 12:52 PM
rdunn
Aug 14, 2004 02:48 AM
