weber carb conversion help
Old Oct 22, 2007 | 08:54 PM
abgriffin's Avatar
Default weber carb conversion help
i recently purchased a wber carb for my 87 b2600 4x4.everything went well, but now i get no fuel from the fuel pump. the pump is in the tank.i removed all the junk from thedrivers side compartment but i now i dont get any fire to the pump itself.any help because i know it must be something simple.thanks for any help.
Old Oct 22, 2007 | 09:13 PM
hixx's Avatar
Default RE: weber carb conversion help
It has a fuel pump control unit,a fuel cut relay and engine speed switch. You can bypass those by powering the fuel pump in key on position. The black/white wire off the ignition switch is the power for that circuit i believe.
HITDOGG
May 13, 2018 11:06 AM
greasemonkey2319
Jan 25, 2009 04:11 AM
blasphemous
Feb 28, 2007 03:02 AM
bryan26
Jun 27, 2006 12:15 PM
varbcorp
Jun 19, 2006 02:43 AM
