Water Pump Problem
Old Oct 13, 2009 | 01:20 AM
dlucas7's Avatar
Default Water Pump Problem
Somebody has had to replace a water pump and if you did where did u use the the little O Ring that comes with the new gasket. It has to go some where andy help would be greatly appreciated
Old Oct 13, 2009 | 02:25 PM
mazdab2600's Avatar
the only place that comes to mind is,the heater crossover pipe on my 2600,hooked into the back off the pump with the o-ring on the pipe lubed with some silicone spray and press fit into the pump then used the mounting tabs on the pipe.
Old Oct 13, 2009 | 08:30 PM
dlucas7's Avatar
thanks for the respond but i have checked it over and over and just dont see a spot. The thing that concerns me is that it didnt smoke when running except for some blue smoke that stopped after you ran it awhile. After i changed the water pump it smokes with more of a white smoke.
sbd1960
Jan 31, 2009 07:21 PM
oz_guy
Apr 6, 2007 01:11 PM
Big_Block_Mopar
Jan 19, 2007 03:08 PM
ginman999
Nov 1, 2006 12:05 AM
KuroRyu256
Jun 23, 2006 10:50 PM
