Thermostat housing issues
Old Jun 28, 2019 | 05:41 PM
mazdabravo's Avatar
Default Thermostat housing issues
The thermostat housing on my Mazda Bravo keeps leaking. I have removed the whole assembly 2 times with new gaskets and heat resistant silicone and it still leaks. Any suggestions would be greatly appreciated.
Old Jun 28, 2019 | 06:34 PM
Replace it. Look for cracks or corrosion.
Old Jun 28, 2019 | 07:06 PM
mazdabravo's Avatar
Thanks.
Old Jun 29, 2019 | 09:21 AM
Cusser's Avatar
Take off the thermostat housing. Check it for absolute straightness/flatness in several directions. If not absolutely flat, sand it flat with a piece of wet/dry on a sheet of glass (or buy a new thermostat housing), then wash off, dry, and install using new gasket and thin coat of RTV. Allow the RTV to set up for a few hours before adding coolant.
Old Jun 29, 2019 | 04:21 PM
mazdabravo's Avatar
Yes I’ve done all of what you’ve said and still It leaks. I think I’ll just replace the whole assembly. Thanks
Old Jul 3, 2019 | 08:34 AM
Cusser's Avatar
I also jack up the front right corner of the truck, gravity helps keep the thermostat in place that way.
Airdwayne
Oct 30, 2015 04:35 AM
miatababe1997
Dec 31, 2010 04:21 PM
jboogyrockdamic
Nov 20, 2006 01:39 AM
Clem
Mar 24, 2006 11:10 AM
