Tailgate latch is broken
Old Apr 21, 2006 | 12:25 PM
defaced's Avatar
Default Tailgate latch is broken
I just bought an 89 B2200 with a cap over the the bed. The glass window of the cap will open but I can't open the tailgate because the latch is broken. I tried pulling the latch from the inside but it still won't come down. Any ideas on how I could possibly fix it or just get a new tailgate? I kind of need to open it because I need to get some crap in there that won't fit through just the pull up window.
Anybody else have this problem or could give me some incite on how to go about just installing a new latch?
Old Apr 21, 2006 | 08:34 PM
babyhuey's Avatar
Default RE: Tailgate latch is broken
I take you have removed the inspection/access cover on the inside as you report that you tried to pull it from the inside. Just pull both rods that are extending out to the latches inward and it should release so you can get the tailgate open and see what is broken. Is usually the outer latch handle itself which is very easy to install a new one.
Old Apr 22, 2006 | 11:39 AM
defaced's Avatar
Yeah, I believe that it is just the handle itself on the outside. I have tried pulling the two rods inward from the inside though and still couldn't get it to come down. I'll try it again today and just try a little harder.
Old Apr 23, 2006 | 12:40 AM
bkey71's Avatar
If it has been stuck for a long time it might be best to try a pair of pliers on each rod at the same time. Is there any body damage in the tailgate area that might keep the latches stuck?
Old Apr 23, 2006 | 01:57 AM
defaced's Avatar
Well I figured it out. It wasn't the actual latch that is broken, just the handle on the outside. I pulled on both of the rods and got it to open. I might fix the handle, might not.
Old May 2, 2006 | 04:00 AM
poorboy_616's Avatar
Go to any NAPA autoparts store and ask to look in the Parts, supplies and Accessories (PSA) catalog.
The tailgate handles for Mazda trucks are in there.
I looked one up today for a customer and myself (I work for NAPA), Here is the NAPA Balkamp number:
735-5054 Tailgate handle Mazda Pickups 1986-1993
Prices very by store, so I would call you nearest store to get it.
Hope this helps,
Pete
dave44135
Jul 31, 2012 01:56 PM
Elementality
May 2, 2012 10:27 AM
chinojuan
Feb 3, 2012 01:23 PM
boweasel
Jan 25, 2011 06:09 PM
smith3621
Oct 12, 2008 09:14 AM
