maf
Old Mar 24, 2009 | 05:13 PM
bloodsweatgears's Avatar
Default maf
i have a 92 b2200 f.i. 5spd. does anyone know if a bad mass air flow sensor would cause my truck not to start in cold weather (45 f or below)? above 45f it will start but hesitates when i try to drive. below that it might start, but only run for less than a minute and then won't start at all after that unless i let it sit overnight. any help would be appriciated. thanks.
Old Mar 24, 2009 | 07:48 PM
hixx's Avatar
It can,try cleaning the hotwire. A cold engine requires a rich fuel mixture to start and run properly so the fuel pressure is bumped up on cold start til warmup. A vacuum leak/bad ECT/fuel pressure regulator/etc can cause what you describe. I would run a fuel pressure test on it before replacing parts. Even excessive carbon can cause what you describe.
Old Mar 25, 2009 | 06:04 AM
fuel pressure is good, can not find any vacuum leaks, had computer rebuilt. how would i check fuel pressure regulator and where would i find the carbon build up. truck ran strong before this problem, would like to save it if i could.
thanks.
FluffySheepBoy
Mar 7, 2007 11:56 AM
theguy
Dec 29, 2006 10:01 PM
theguy
Dec 15, 2006 12:00 AM
davelourenzo
Dec 1, 2006 08:31 PM
michael91077
Feb 20, 2006 03:23 PM
