gotta figure this out please help
Old Mar 14, 2025 | 07:16 PM
willis1313's Avatar
Default gotta figure this out please help
recently came into ownership of a 02 b3000 3.0v6 with some issues has a extreme loss of power has a hiccup when pressing the gas horrible fuel milage spark plugs read running really rich and where way over gapped have been replaced it I can't take it on the highway because it won't go over 55 mph it only has 115k on the motor if I give it throttle under load when it down shifts sounds like its going to blow up and when I first start it in the morning it revs up to almost 3000 rpm and sits there for a solid 3o to 45 sec then will drop back down and run fine till it gets up to temp thats when all the fun starts once its at running temp it can't be driven long as the longer its driven while the issues are apparent they gradually get worse exhaust will spit black stuff out but never smokes replaced the crank position sensor with no affect I used to have a Nissan frontier that I had to replace the distributor along with the crank position sensor is it the same possibly im at a loss now any insite would be awesome thanks
Old Mar 14, 2025 | 08:56 PM
Have you had it scanned for fault codes?
Old Mar 14, 2025 | 09:08 PM
willis1313's Avatar
my father in law scanned it he's the one told me it needed crank position sensor changed said he cleared the code after scan but I personally have not been able to yet thats set for tomorrow
Old Mar 15, 2025 | 10:43 AM
willis1313's Avatar
so scanned the codes today and im getting maf low circut code running rich on both banks and a code for vid something about ecm corruption or reprograming and a misfire in cylinder 2
Old Mar 15, 2025 | 11:01 AM
The scan was not done correctly and clearing the DTC only turned off the check engine light on the dash
Old Mar 16, 2025 | 12:16 PM
MeB2000's Avatar
Punctuationisanimportantpartinconveyinginformation toothersonaforum!
Old Mar 16, 2025 | 12:38 PM
ryan44b
May 20, 2021 03:56 PM
corn
Jul 24, 2018 10:48 PM
memphis2857
Mar 21, 2012 11:27 AM
isaac2484
Nov 27, 2009 11:50 PM
90Rx7
Jan 2, 2006 11:01 PM
