Carburetor Question
I was wondering if anyone knows whether the carb off a 2.0L 1985626 would fit the B2000 which is a 2.0 liter as well.The carburetorslook identical down to the wiring plugand bolt on pattern.Someone told me it can be done and that there were justsome vacume line differences to adjust for?
Yes it fits but there's a little bit adjustment on it. Mazda carburetor is hard to fit to other model type but the dealer have a solution for it I'm sure.
theres also a guy by the name of EFlores who rebuilds them cheaper
yes it will fit....no the jetting isnt different, it will run fine except the choke is different i believe on some models of 626, there is a write up i did on another mazda board about how to do away with all the vac lines and which ones you need for the computer control to still function correctly
http://www.mazdatruckin.com
yes it will fit....no the jetting isnt different, it will run fine except the choke is different i believe on some models of 626, there is a write up i did on another mazda board about how to do away with all the vac lines and which ones you need for the computer control to still function correctlyhttp://www.mazdatruckin.com
