Brake Shoe Reversal
Old Oct 17, 2023 | 10:02 AM
Mickey12's Avatar
Default Brake Shoe Reversal
Mazda Brakes B3000 1999 Duo-Servo brakes, I assume? Unable to place new drum on new rear shoes. I’ve discovered that there should be a front primary shoe and a secondary back shoe on each wheel. I think I installed them backwards. However, the pin that holds the e-brake cable is attached to the primary shoe which is now on the secondary (back) position. Is this assumption correct? Can I remove and replace the pin and install it on the on the secondary shoe once I flip them correctly? So I then have a larger front primary shoe and a smaller secondary back shoe? Photos are of the passenger’s side of vehicle.
Old Oct 21, 2023 | 04:27 PM
MeB2000's Avatar
Instead of removing the pin.......are the shoes swapped and are on the wrong side of the truck? You may have the right on the left, and vise versa.
Old Oct 21, 2023 | 07:26 PM
Mickey12's Avatar
lot of conflicting info out on the internet. on ranger and mazda trucks, the primary or longer shoe goes in the back. The shorter shoe goes in the front. So, we should be mounted correctly. I getting the drums spec next week to see if they are correct. thanks for you're comment.
Old Nov 21, 2023 | 03:25 PM
90-B2200's Avatar
Also make sure you have the auto adjuster seated properly and it is adjusted to its absolute shortest length. Also, if the e brake cable is not releasing fully it can hold the shoes open a bit making it difficult to get the drum on.
Mickey12
Oct 17, 2023 09:36 AM
Demanius
Oct 28, 2022 05:42 PM
mazdab2600
May 23, 2009 08:52 PM
zoomzoomwannabe
13
Feb 11, 2007 01:30 PM
miguerh
Aug 13, 2006 11:05 PM
