All heat, all the time
Old Apr 30, 2009 | 07:37 AM
NCB2300's Avatar
Default All heat, all the time
Preface: My AC only works in Max AC. Every other setting gets me full heat.
I posted in my intital thread that the research I'd done let me to believe my truck's temperature selector **** was attached to the air blend door by a cable; NOT so.
I removed the center cover panel and there isn't a cable. My truck's temperature selector **** has wires attached that disappear into the dash... somewhere. So, the **** is a rheostat/potentiometer I'm guessing. All of the vacuum actuators appear to be working normally (feel test - select defrost, air blows from defroster ducts, etc).
Has anyone solved this 'all heat' type problem recently that can relate a fix. Replace the ****? Replace the water valve? Actuator somewhere?
Thanks for reading.
Old May 1, 2009 | 10:24 AM
NCB2300's Avatar
Ah... I found the culprit and the fix over on a Ford Explorer site. HVAC air blend door ... Seems this is an uber-common problem - 30 + pages of threads. Not a simple fix, but at least there is a fix.
Link to site
Epoxy
Jan 5, 2010 10:05 AM
asianstutter
Dec 11, 2008 03:37 PM
Reggie08
Jun 3, 2008 12:07 PM
fleurya
Feb 12, 2008 09:32 PM
ishan.desilva
Mar 28, 2007 03:12 PM
