89 b2200 lift kit
Old Nov 25, 2006 | 01:46 AM
89_b2200's Avatar
Default 89 b2200 lift kit
i just got an 89 b2200 2 door short bed with a 5 sp.
i was wondering what kind of lift kits are out there because i cant find any suspension lifts
i guess my only option is to do a body lift. what is the best one?
but my only worries with this is that i have heard that with body lifts, you have to get steering and shifter extentions. Is this true? What else will be needed with a body lift and where do i get this stuff.
Thanks for the help
KYLE
Old Nov 25, 2006 | 03:46 AM
mazdab2600's Avatar
Default RE: 89 b2200 lift kit
look at the post for 33 inch tire's https://www.mazdaforum.com/m_31195/tm.htm
the 2200's are very close to the 2600's
took a cab off a 87 2200 and put it on my 91 2600
Old Dec 3, 2006 | 11:22 PM
Chaney's Avatar
I bought a suspension lift for my 2600 of ebay. It came with new leaf springs for the back and new torsion bars for the front, and also new shocks. I haven't had tome to install it yet. Looks like it will make it look nice. Here is the link to Ebay http://cgi.ebay.com/ebaymotors/ws/eB...m=330001894209
Good luck
Old Dec 12, 2006 | 12:48 PM
DrNuts's Avatar
Could this also fit the b2200 with a little work? I have a 3" body lift kit now and run 31" tires but would like to go with 33s. Any help would be appreciated.
BTW: She is a V8
Mark
Old Dec 14, 2006 | 08:34 PM
Orangerims's Avatar
Chaney,
Thanks for the link man. Those 2.5" inch lifts kits are near impossible to find, ive been looking for over a year now! Lucky thing they had 8 left in stock. Ought to be a good bolt on for the truck!
Old Dec 16, 2006 | 12:07 AM
Chaney's Avatar
I just installed my last week I did the rear and had a shop do my torsion bars only charged me $110 to do the bars and the shocks. I could adjust them up a few more inches, but i'm out of adjustment for my alignment on the front.
Old Dec 16, 2006 | 11:38 AM
blasphemous's Avatar
Where are you guys at? That lift kit isn't priced too bad coming w/ new leafs and shocks too. You can only run about 2" of lift in the front without completely destroying A-arm bolts, ball joints, tie rod ends and CV angles. You wonder how I know? Because I done it...
I had 3" blocks in the rear and the front cranked up about 5". CV shafts didn't fit anymore, so I took out the blocks and lowered the front about 2". CV anges were horrible, tore up boots all the time and wore out ball joints in about 3 months tops.
The stock suspension just isn't made to handle those kind of angles. I've asked on here if anyone would be interested in custom A-arms and a diff drop. I could make them for 5" of lift in the front then you'd need about 3" in the rear to level out the truck. I was going to use a set of stock A-arms and use DOM tubing to move the ball joints location and angle for the lift to give all the proper geometry back and maintain a bolt-in application.
Chaney
Sep 23, 2013 02:19 PM
Chaney
Nov 16, 2010 08:13 AM
fastisnothing
Jun 13, 2008 10:20 AM
andrew
Mar 22, 2007 09:56 AM
Warrior
Jul 29, 2006 02:38 AM
